Lenovo IdeaPad 3-1481W000NGUS RAM Replacement
  1. Lenovo IdeaPad 3-1481W000NGUS RAM Replacement, Back Cover: step 1, image 1 of 3 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement, Back Cover: step 1, image 2 of 3 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement, Back Cover: step 1, image 3 of 3
    Tool used on this step:
    Magnetic Project Mat
    $19.95
    Buy
    • Orient the laptop so that the bottom is facing up.
    • Remove the six 7 mm screws using a Phillips #00 screwdriver.
    • Remove the four 4 mm screws using a Phillips #00 screwdriver.
  2. Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 2, image 1 of 3 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 2, image 2 of 3 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 2, image 3 of 3
    • Pry up the sides of the back case using the iFixit opening tool. Then, lift to remove.
    • You may hear snapping when removing the panel. This is normal!
  3. Lenovo IdeaPad 3-1481W000NGUS RAM Replacement, RAM: step 3, image 1 of 2 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement, RAM: step 3, image 2 of 2
    • Use your fingernail or an opening tool to gently pull out and disconnect the battery pack cable.
    • Do not pull on the cables.
  4. Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 4, image 1 of 2 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 4, image 2 of 2
    • Disengage the latch of the RAM by pushing outwards on the left and right side of the memory module slot.
  5. Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 5, image 1 of 2 Lenovo IdeaPad 3-1481W000NGUS RAM Replacement: step 5, image 2 of 2
    • Remove the RAM by sliding it out of its slot.
Mycah Detorres
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 16
All Time: 254
