Lenovo IdeaPad 3-15IIL05 Battery Replacement
  1. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the back cover: step 2, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the back cover: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: step 3, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: step 3, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: step 3, image 3 of 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: step 4, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: step 4, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the left clips: step 4, image 3 of 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: step 5, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: step 5, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the bottom clips: step 5, image 3 of 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: step 6, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: step 6, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the right clips: step 6, image 3 of 3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: step 7, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Insert an opening pick: step 7, image 2 of 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: step 8, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: step 8, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Release the top clips: step 8, image 3 of 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: step 9, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: step 9, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the back cover: step 9, image 3 of 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: step 10, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: step 10, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Disconnect the battery: step 10, image 3 of 3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the battery: step 11, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Unfasten the battery: step 11, image 2 of 2
    • Use a Phillips screwdriver to remove the three 5.7 mm-long screws securing the battery.
  12. Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the battery: step 12, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Battery Replacement, Remove the battery: step 12, image 2 of 2
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Check your repair by running hardware tests with Lenovo Diagnostics.
3 other people completed this guide.
Spencer Day
94,530 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
One Comment
Great instructions. Tools were perfect.
Stuwas - Reply
Past 24 Hours: 28
Past 7 Days: 127
Past 30 Days: 458
All Time: 8,739
