Lenovo IdeaPad 3-15IIL05 Speakers Replacement
  1. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Prepare your laptop for disassembly: step 1, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Prepare your laptop for disassembly: step 1, image 2 of 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Unfasten the back cover: step 2, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Unfasten the back cover: step 2, image 2 of 2
    • Use a Phillips screwdriver to remove the ten screws securing the back cover:
    • Six 7.6 mm-long screws
    • Four 4.7 mm-long screws
  3. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Insert an opening pick: step 3, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Insert an opening pick: step 3, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Insert an opening pick: step 3, image 3 of 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release.
    • Insert the flat side of an opening pick between the top left corner of the back cover and frame.
    • Angle the pick down to about 45 degrees.
  4. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the left clips: step 4, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the left clips: step 4, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the left clips: step 4, image 3 of 3
    • Keep the opening pick angled down at about 45 degrees while sliding it along the front and side edges to help release the clips.
    • Slide the pick to the bottom left corner of the laptop to release the left clips.
  5. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the bottom clips: step 5, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the bottom clips: step 5, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the bottom clips: step 5, image 3 of 3
    • Slide the opening pick to the bottom right corner to release the bottom clips.
  6. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the right clips: step 6, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the right clips: step 6, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the right clips: step 6, image 3 of 3
    • Slide the opening pick to the top right corner to release the right clips.
  7. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Insert an opening pick: step 7, image 1 of 2 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Insert an opening pick: step 7, image 2 of 2
    • Insert the flat end of an opening pick between the back cover and frame, to the left of the right hinge.
    • Pry the back cover up with the pick to release the top right clips.
    • Leave the pick inserted next to the right hinge.
  8. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the top clips: step 8, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the top clips: step 8, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Release the top clips: step 8, image 3 of 3
    • Angle the pick up to about 45 degrees.
    • Slide the opening pick to the top left corner to release the remaining clips.
  9. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the back cover: step 9, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the back cover: step 9, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the back cover: step 9, image 3 of 3
    • Remove the back cover.
    • During reassembly, lay the back cover on the frame and press firmly around the perimeter to engage all the clips.
  10. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the battery: step 10, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the battery: step 10, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the battery: step 10, image 3 of 3
    • Use the flat end of a spudger to gently push the battery connector out of its socket on the motherboard.
  11. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the speakers: step 11, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the speakers: step 11, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Disconnect the speakers: step 11, image 3 of 3
  12. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Reposition the speaker cables: step 12, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Reposition the speaker cables: step 12, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Reposition the speaker cables: step 12, image 3 of 3
    • Guide the speaker wire out of the two metal clips securing it to the frame.
  13. Lenovo IdeaPad 3-15IIL05 Speakers Replacement: step 13, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement: step 13, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement: step 13, image 3 of 3
    • Plastic clips along the bottom edge of the laptop secure the cable connecting the left and right speaker.
    • Use the point of a spudger to gently guide the cable out of the plastic clips.
  14. Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the speakers: step 14, image 1 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the speakers: step 14, image 2 of 3 Lenovo IdeaPad 3-15IIL05 Speakers Replacement, Remove the speakers: step 14, image 3 of 3
    • Small rubber grommets secure the speakers to the frame.
    • Lift and remove the speakers.
    • During reassembly, align the speakers over their recesses and press them into place to secure them.
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
94,530 Reputation
662 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 713
