Lenovo IdeaPad 330S-14IKB Battery Replacement
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: step 1, image 1 of 1
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: step 2, image 2 of 2
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 3, image 1 of 1
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 4, image 1 of 1
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 5, image 1 of 1
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 6, image 1 of 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: step 6, image 2 of 2
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: step 7, image 1 of 2 Lenovo IdeaPad 330S-14IKB Battery Replacement: step 7, image 2 of 2
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 14
All Time: 246
