Lenovo IdeaPad 330S-14IKB RAM Replacement
Luke Garrett
Luke Garrett and 6 other contributors
Last updated on March 20, 2024
2 - 5 minutes
Very easy
Introduction
Go to step 1
RAM is a part that does not typically fail, however it is not invulnerable. If your Lenovo Ideapad 330S-14IKB begins to show signs of failing RAM such as random freezes, blue screens, randomly rebooting, and files becoming corrupted, it could mean it is time to replace it.
  1. Lenovo IdeaPad 330S-14IKB RAM Replacement, RAM: step 1, image 1 of 1
    • Begin by placing your laptop upside down so that you can see the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 2, image 1 of 2 Lenovo IdeaPad 330S-14IKB RAM Replacement: step 2, image 2 of 2
    • Remove the 10 screws from the bottom of the laptop.
    • (Silver, 5.8mm Phillips #0)
    • Safely store these screws in a secure location, like a magnet pad, to prevent them from getting lost.
  3. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 3, image 1 of 1
    • Carefully remove the back panel from the laptop.
    • Be sure to proceed slowly and use wedges to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 4, image 1 of 1
    • Locate the black panel and remove these three black screws.
    • (Black, 5.83mm Phillips #0)
  5. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 5, image 1 of 2 Lenovo IdeaPad 330S-14IKB RAM Replacement: step 5, image 2 of 2
    • To access your RAM, remove the black panel you just removed the screws from.
    • Remember to keep these screws separate and do not mix them with others.
  6. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 6, image 1 of 1
    • Your RAM will be a blue rectangle, positioned almost in the center of the device.
  7. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 7, image 1 of 2 Lenovo IdeaPad 330S-14IKB RAM Replacement: step 7, image 2 of 2
    • To remove your RAM, gently pull back on the metal clips holding it in place.
    • Carefully slide the RAM out of the slot.
    • Be gentle to avoid damaging the slot
  8. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 8, image 1 of 1
    • Now, take your new RAM module and locate the notch on it.
  9. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 9, image 1 of 1
    • Align the notch on your replacement RAM as shown in the previous step with the corresponding slot on the device's RAM slot.
  10. Lenovo IdeaPad 330S-14IKB RAM Replacement: step 10, image 1 of 2 Lenovo IdeaPad 330S-14IKB RAM Replacement: step 10, image 2 of 2
    • Gently insert the RAM module.
    • Once it's as far in as it can go, lower it slowly until the metal clips lock it into place.
    • You should hear an audible click when it's securely in place.
To reassemble your device, follow steps 6-1 in reverse order.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 41
All Time: 431
