Lenovo IdeaPad 330S-15ARR Fan Replacement
  1. Lenovo IdeaPad 330S-15ARR Fan Replacement, Back Panel: step 1, image 1 of 3 Lenovo IdeaPad 330S-15ARR Fan Replacement, Back Panel: step 1, image 2 of 3 Lenovo IdeaPad 330S-15ARR Fan Replacement, Back Panel: step 1, image 3 of 3
    • Remove the ten 3.3 mm screws securing the back panel using a Phillips #00 screwdriver.
    • Use a Jimmy or your fingernail to pry the back panel off.
  2. Lenovo IdeaPad 330S-15ARR Fan Replacement, Fan: step 2, image 1 of 3 Lenovo IdeaPad 330S-15ARR Fan Replacement, Fan: step 2, image 2 of 3 Lenovo IdeaPad 330S-15ARR Fan Replacement, Fan: step 2, image 3 of 3
    • Remove the six 3 mm screws from the black board using a Phillips #00 screwdriver.
    • Remove the black board.
  3. Lenovo IdeaPad 330S-15ARR Fan Replacement: step 3, image 1 of 2 Lenovo IdeaPad 330S-15ARR Fan Replacement: step 3, image 2 of 2
    • Remove the black electrical tape from the fan.
  4. Lenovo IdeaPad 330S-15ARR Fan Replacement: step 4, image 1 of 1
    • Disconnect the fan from the circuit board by pulling on the plastic part of the wire towards the fan.
  5. Lenovo IdeaPad 330S-15ARR Fan Replacement: step 5, image 1 of 1
    • Remove the five 3 mm screws holding the fan in place using a Phillips #00 screwdriver.
  6. Lenovo IdeaPad 330S-15ARR Fan Replacement: step 6, image 1 of 1
    • Lift the fan to remove it from the laptop.
Jacob McPhee
291 Reputation
2 Guides authored
UMass Dartmouth, Team 2-4, Konn Fall 2024 Member of UMass Dartmouth, Team 2-4, Konn Fall 2024
UMASSD-KONN-F24S2G4
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 27
All Time: 94
