Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement
  1. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Unfasten the back cover: step 1, image 1 of 2 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Unfasten the back cover: step 1, image 2 of 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: step 2, image 1 of 3 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: step 2, image 2 of 3 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 2 Loosen the back cover: step 2, image 3 of 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 3 Remove the back cover: step 3, image 1 of 2 Lenovo IdeaPad 5 15ITL05 Back (Bottom) Cover Replacement, Step 3 Remove the back cover: step 3, image 2 of 2
    • Once all the tabs are loose, you will be able to remove the cover.
E N
476 Reputation
3 Guides authored
One Comment
I would call that the bottom cover. I want to see the back cover of the screen replaced. Including the electronics attached to it!
Bruce Cox - Reply
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 81
All Time: 979
