Lenovo IdeaPad 5 15ITL05 Battery Replacement
  1. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: step 1, image 1 of 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the back cover: step 1, image 2 of 2
    • Use a T5 Torx driver to remove nine screws securing the back cover.
    • The three screws on the hinge side will be longer.
  2. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: step 2, image 1 of 3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: step 2, image 2 of 3 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 2 Loosen the back cover: step 2, image 3 of 3
    • The back cover is held on by plastic tabs around the entire perimeter of the cover.
    • Use plastic pry tools at the seam. I like to start near the hinge.
  3. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: step 3, image 1 of 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 3 Remove the back cover: step 3, image 2 of 2
    • Once all the tabs are loose, you will be able to remove the cover.
  4. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: step 4, image 1 of 2 Lenovo IdeaPad 5 15ITL05 Battery Replacement, Disconnect the battery: step 4, image 2 of 2
    • Use the flat end of a spudger to push the square tab on the battery connector and slide it out of its socket.
  5. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Unfasten the battery: step 5, image 1 of 1
    • Use a Phillips screwdriver to remove the four screws securing the battery.
    • Note: Two of the screws on the left in the image will also hold in the SATA drive bracket.
  6. Lenovo IdeaPad 5 15ITL05 Battery Replacement, Step 6 Remove the battery: step 6, image 1 of 1
    • Remove the battery.
E N
449 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 52
All Time: 507
