Lenovo IdeaPad 720S-13IKB CPU Fan Replacement
  1. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove back cover: step 1, image 1 of 1
    • Power off Device
    • Remove charger
    • Remove 6 T5 Screws
    • Remove 4 T5 Screws (These Screws are at an angle)
    • Remove the back cover using opening Pics. Start at the back(where the screen is)
  2. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: step 2, image 1 of 1
    • SSD/DisplayConnector Cover
    • Battery
    • M.2 Wifi&Bluetooth
    • Speakers
    • RAM Cover
    • CPU
  3. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Battery: step 3, image 1 of 1
    • Unplug battery
    • Remove all 3 Screws using PH1
    • Take out the battery
  4. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: step 4, image 1 of 1
    • Fingerprint reader
    • Touchpad
  5. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Covers: step 5, image 1 of 2 Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Covers: step 5, image 2 of 2
    • Remove Screws with PH1
    • Remove Screws with PH0
    • Remove RAM cover
    • All covers are also secured using contact clips (Picture 2). Just pull them out
  6. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: step 6, image 1 of 1
    • DRAM (K4aag165wb MCRC)
    • Connector To Display
    • M.2 SSD
  7. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Speaker: step 7, image 1 of 1
    • Unplug Fans
    • Disconnect Fingerprint and Touchpad
    • Take out Speakers
  8. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Motherboard: step 8, image 1 of 2 Lenovo IdeaPad 720S-13IKB CPU Fan Replacement, Remove Motherboard: step 8, image 2 of 2
    • Remove screws using PH0
    • Remove screws using PH1 and take m.2 parts out
    • Dissconnect cables
    • Disconnect Display Cable
    • No Idea how to connect Display Cable (Tips welcome)
    • Push Moterboard to the left and take it out.
    • At the USB-A Port is some cushion to keep the Motherboard in place.
    • follow Teardown till covers are removed (Step 5)
  9. Lenovo IdeaPad 720S-13IKB CPU Fan Replacement: step 10, image 1 of 1
    • Disconnect fan cable
    • Unscrew using PH1
    • Take Fan Out
Hinomi
325 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 12
