Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement
  1. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: step 1, image 1 of 2 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Lenovo IdeaPad Flex 3 CB 11M735 Disassembly: step 1, image 2 of 2
    • It's best to touch the ground before you start to be sure you won't shock any components.
    • Use a T6 Torx screwdriver to unscrew the nine M2 x 6.5mm screws.
  2. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: step 2, image 3 of 3
    • Using a plastic spudger, carefully lift the palmrest from the bottom cover.
    • Be careful while removing the keyboard, and unplug the connections.
  3. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement, Battery: step 3, image 1 of 1
    • Disconnecting the battery from the motherboard.
  4. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: step 4, image 1 of 1
    • Use a PH00 screwdriver to remove the 3x(M2x4mm) screws.
  5. Lenovo IdeaPad Flex 3 CB 11M735 Battery Replacement: step 5, image 1 of 1
    • Ensure the replacement battery is right, then follow the steps backward to assemble everything.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 392
