Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement
  1. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement, Cmos battery: step 3, image 1 of 1
    • Using the JIS #0 screwdriver unscrew the three battery screws.
  4. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 4, image 1 of 1
    • Lift up the battery from the long, bottom edge.
    • Remove the battery from the laptop and place it nearby.
  5. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 5, image 2 of 2
    • Remove the red and black annotated cable, pulling white head out of black port as indicated.
  6. Lenovo IdeaPad Flex 4-1470 Cmos battery Replacement: step 6, image 1 of 1
    • Ply the CMOS battery off with your finger.
    • The battery is attached to the computer by adhesive, but should come off by pulling with fingers; plying tool should not be necessary.
2 other people completed this guide.
Elijah Ellis
616 Reputation
5 Guides authored
One Comment
Does this procedure reset the BIOS?
Mark Webb - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 2,611
