Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement
  1. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: step 3, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement, Cooling Fan: step 3, image 2 of 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 4, image 1 of 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 4, image 2 of 3 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Cooling Fan Replacement: step 5, image 2 of 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
Demario Robinson
1,038 Reputation
4 Guides authored
USF Tampa, Team S1-G6, Thompson Fall 2017 Member of USF Tampa, Team S1-G6, Thompson Fall 2017
USFT-THOMPSON-F17S1G6
3 Members
10 Guides authored
One Comment
will the same fan fit to lenovo ideapad flex 5 1470 ?
Rajeshwar Choudhary - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 1,653
