Lenovo IdeaPad Flex 4-1470 Motherboard Replacement
  1. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: step 3, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Cooling Fan: step 3, image 2 of 2
    • Remove the two 4 mm Phillips #0 screws which mount the fan.
  4. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 4, image 1 of 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 4, image 2 of 3 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using the Precision Tweezers, remove the 2 gray wires around the fan from their clips.
  5. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 5, image 2 of 2
    • Use 2 plastic opening tools to remove the fans power wire from the Mother board and remove the fan.
    • Lift the cooling fan out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Wifi Card: step 6, image 1 of 1
    • Remove the foam on the WIFI card.
  7. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 7, image 1 of 1
    • Remove the wires attached to the WIFI card.
  8. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 8, image 1 of 1
    • Unscrew the 4mm screw holding wifi card.
  9. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement, Motherboard: step 9, image 1 of 1
    • Unscrew the twelve 4mm screws with a #0 Phillips screwdriver.
  10. Lenovo IdeaPad Flex 4-1470 Motherboard Replacement: step 10, image 1 of 1
    • Remove the motherboard.
    • The motherboard will be in place when the screw holes line up.
2 other people completed this guide.
Elijah Ellis
616 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,299
