Lenovo IdeaPad Flex 4-1470 Touchpad Replacement
  1. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: step 3, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery connector by using a plastic pry tool or your fingers to push the cable right towards the battery.
    • Do not pry or push on the socket itself or you risk damaging the motherboard.
  4. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 4, image 1 of 1
    • Remove the three 4 mm Phillips #0 screws holding the battery in place.
  5. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 5, image 1 of 1
    • Lift the battery up and out of the laptop.
  6. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement, Touchpad: step 6, image 1 of 1
    • Locate the touchpad.
  7. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 7, image 1 of 2 Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 7, image 2 of 2
    • Remove the three ribbon cables surrounding the touch pad.
  8. Lenovo IdeaPad Flex 4-1470 Touchpad Replacement: step 8, image 1 of 1
    • Lift the base of the laptop from the screen and gently push the touchpad to remove.
2 other people completed this guide.
Elijah Ellis
616 Reputation
5 Guides authored
2 Comments
do you know where to find this part? i have been looking everywhere haha.
Hanna Tafete - Reply
Can any body repair lenovo idea pad 1470. Touch screen ...tia
jgonzales - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 1,219
