Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement
  1. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, Lower Case: step 1, image 1 of 1
    • Ensure your computer is completely OFF before starting this guide.
    • Remove the eight 6 mm screws using a Phillips #0 screwdriver.
    • Remove the two 11 mm screws using a Phillips #0 screwdriver.
  2. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: step 2, image 2 of 2
    • Pry the back cover off by inserting the plastic opening tool at the hinges and wedging it between the Back cover and the body.
    • Follow along the back edge with the plastic opening tool, lifting the cover off as you go. It is normal to hear snapping/clicking sounds as the back cover is held on by clips.
    • Remove the cover.
  3. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: step 3, image 1 of 2 Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement, USB/SD Card Hub: step 3, image 2 of 2
    • Remove the 4mm screw with a JIS #0 screwdriver.
  4. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: step 4, image 1 of 1
    • Remove the ribbon cable.
  5. Lenovo IdeaPad Flex 4-1470 USB/SD Card Hub Replacement: step 5, image 1 of 1
    • Remove the existing USB hub and replace it with the new hub.
Elijah Ellis
616 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 348
