Lenovo IdeaPad Flex 5-1470 Battery Replacement
  1. Lenovo IdeaPad Flex 5-1470 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Battery Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Battery Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Battery Replacement, Battery: step 3, image 1 of 1
    • Remove the two 3.6 mm Phillips #00 battery screws located in the lower left corner of the device.
  4. Lenovo IdeaPad Flex 5-1470 Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Battery Replacement: step 4, image 2 of 2
    • Gently unplug the multi-colored cable connecting the battery to the motherboard.
    • Remove the battery from the laptop.
2 other people completed this guide.
Tori Nardoni
286 Reputation
3 Guides authored
Cal Poly, Team S2-G5, White Winter 2020 Member of Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 54
All Time: 4,083
