Lenovo IdeaPad Flex 5-1470 Motherboard Replacement
  1. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, SSD: step 3, image 1 of 1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
  4. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: step 4, image 1 of 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: step 4, image 2 of 3 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement, Motherboard: step 4, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the three screws securing the fan.
    • Lift the fan up and out.
    • Use a Phillips #00 screwdriver to remove the three screws securing the hard drive.
    • Lift the hard drive up and out.
  5. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 5, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the single screw securing the Wi-Fi card.
    • The Wi-Fi card will slightly lift away from the motherboard.
    • Pull the Wi-Fi card directly out of its port.
  6. Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 6, image 1 of 2 Lenovo IdeaPad Flex 5-1470 Motherboard Replacement: step 6, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the three screws securing the motherboard.
    • Gently disconnect the cables and ribbon cables connected to the motherboard.
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 469
