Lenovo IdeaPad Flex 5-1470 SSD Replacement
  1. Lenovo IdeaPad Flex 5-1470 SSD Replacement, Back Panel: step 1, image 1 of 1
    • Remove all ten 6.6 mm screws with a Phillips #00 screwdriver.
  2. Lenovo IdeaPad Flex 5-1470 SSD Replacement: step 2, image 1 of 2 Lenovo IdeaPad Flex 5-1470 SSD Replacement: step 2, image 2 of 2
    • Use the plastic opening tool to lift up and remove the casing.
  3. Lenovo IdeaPad Flex 5-1470 SSD Replacement, SSD: step 3, image 1 of 1
    • Remove the single 3.6 mm screw using a Phillips #00 screwdriver.
    • The SSD will pop up on its own after removing the screw.
2 other people completed this guide.
Lexie Sakoda
154 Reputation
1 Guide authored
Cal Poly, Team S2-G5, White Winter 2020 Member of Cal Poly, Team S2-G5, White Winter 2020
CPSU-WHITE-W20S2G5
4 Members
16 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 50
All Time: 4,111
