Lenovo IdeaPad Flex 5-1570 Battery Replacement
  1. Lenovo IdeaPad Flex 5-1570 Battery Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Battery Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Battery Replacement, Battery: step 4, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Battery Replacement, Battery: step 4, image 2 of 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 5, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 5, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Battery Replacement: step 5, image 3 of 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
4 other people completed this guide.
Nate Blake
507 Reputation
4 Guides authored
Cal Poly, Team S2-G6, White Winter 2020 Member of Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Members
13 Guides authored
3 Comments
Hullo. In the pic on step -1, near the top left screw, the back cover is cracking up. Whenever, I open the Display panel, the back panel at this point shows tendency to open. The screw is obviously is out of its threading. Is this damage, physical or due to battery swelling. My battery life seems alright. After full charge, it stays for more than 30h with intermittent use. Can you reply to svnarasimhan5@gmail.com
Narasimhan SV - Reply
Hello,
Thank you so much for the guide.
Have a question though, is the following battery compatible for Lenovo Flex 5 1570 (Type 80XB): https://www.ebuyindia.in/products/origin...
Appreciate your help.
Anshul Gandhi - Reply
I bought this battery to replace my old failed battery. The installation went very well. But I soon noticed that the battery and the charging adaptor were getting extremely hot every time I plugged it in. After 1 month the laptop stopped completely. There was absolutely no issues with the laptop before except the battery.
I would never go for an iFixit battery again.
Pragha - Reply
Past 24 Hours: 11
Past 7 Days: 70
Past 30 Days: 275
All Time: 23,858
