Lenovo IdeaPad Flex 5-1570 Fan Replacement
  1. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Fan Replacement, Fan: step 4, image 1 of 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 5, image 1 of 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 6, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Fan Replacement: step 6, image 2 of 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
2 other people completed this guide.
Will Schafer
380 Reputation
2 Guides authored
Cal Poly, Team S2-G6, White Winter 2020 Member of Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Members
13 Guides authored
One Comment
thank you for you share
Liu bing - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 37
All Time: 2,430
