Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement
  1. Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Hard Drive Replacement: step 5, image 2 of 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
Jeremy Schwartz
113 Reputation
1 Guide authored
Cal Poly, Team S2-G6, White Winter 2020 Member of Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Members
13 Guides authored
One Comment
How do I get whats on my hard drive to the new ssd?
jbechtel1 - Reply
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 93
All Time: 7,670
