Lenovo IdeaPad Flex 5-1570 Speaker Replacement
  1. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  5. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 5, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 5, image 2 of 2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  6. Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: step 6, image 1 of 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: step 6, image 2 of 3 Lenovo IdeaPad Flex 5-1570 Speaker Replacement, Speakers: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  7. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 7, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 7, image 2 of 2
    • Using your hands, gently pull the left speaker up and out of the device.
  8. Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 8, image 1 of 2 Lenovo IdeaPad Flex 5-1570 Speaker Replacement: step 8, image 2 of 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
Nate Blake
507 Reputation
4 Guides authored
Cal Poly, Team S2-G6, White Winter 2020 Member of Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 501
