Lenovo IdeaPad Flex 5-1570 USB Port Replacement
Nate Blake
Nate Blake and 4 other contributors
Last updated on May 7, 2021
30 minutes - 1 hour
Difficult
Introduction
Go to step 1
If your Lenovo IdeaPad Flex 5-1570 does not recognize when devices are plugged into the USB port then your device may have a faulty USB port. The USB port allows the laptop to connect to other devices such as a wireless mouse or an external hard drive. This guide will show you how to successfully replace the USB port. Step 10 requires you to desolder the faulty USB port and resolder a new USB port on to the motherboard, so make sure to read the How to Solder and Desolder Connections guide. Be sure to completely turn off and unplug your device from any external power before you start.
Tools
Show more…
  1. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Back Panel: step 1, image 2 of 2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 2, image 1 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 2, image 2 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 2, image 3 of 3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 3, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 3, image 2 of 2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Fan: step 4, image 1 of 1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  5. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 5, image 1 of 1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  6. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 6, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 6, image 2 of 2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  7. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: step 7, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Battery: step 7, image 2 of 2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  8. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 8, image 1 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 8, image 2 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 8, image 3 of 3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  9. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: step 9, image 1 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: step 9, image 2 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Speakers: step 9, image 3 of 3
    Tool used on this step:
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  10. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 10, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 10, image 2 of 2
    • Using your hands, gently pull the left speaker up and out of the device.
  11. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 11, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 11, image 2 of 2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  12. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, Motherboard: step 12, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  13. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 13, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 13, image 2 of 2
    • Disconnect the auxiliary port cable from the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 14, image 1 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 14, image 2 of 3 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 14, image 3 of 3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  15. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 15, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 15, image 2 of 2
    • Disconnect the display cable from the motherboard.
  16. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 16, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 16, image 2 of 2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 17, image 1 of 2 Lenovo IdeaPad Flex 5-1570 USB Port Replacement: step 17, image 2 of 2
    • Carefully lift and remove the motherboard from the device.
  18. Lenovo IdeaPad Flex 5-1570 USB Port Replacement, USB Port: step 18, image 1 of 1
    • Once you've removed the motherboard, desolder the four contact points on the USB connector.
    • For proper technique on soldering and desoldering connections, please visit the How to Solder and Desolder Connections guide.
    • Remove the USB port from the device.
    • Resolder the new USB connector in the same place.
Nate Blake
507 Reputation
4 Guides authored
Cal Poly, Team S2-G6, White Winter 2020 Member of Cal Poly, Team S2-G6, White Winter 2020
CPSU-WHITE-W20S2G6
4 Members
13 Guides authored
2 Comments
what is the replacement part number?
Edwin Maynard - Reply
Was anyone able to find a part number for the specific USB ports?
Greg - Reply
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 41
All Time: 3,140
