Lenovo IdeaPad Flex 6-14IKB Battery Replacement
  1. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Base Cover: step 1, image 1 of 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB Battery Replacement, Battery: step 3, image 1 of 1
    • Remove the four 3.5 mm screws around the battery using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Disconnect the battery supply from the motherboard using a pair of tweezers.
    • Remove the battery from the laptop.
    • If the battery has an adhesive patch on the underside, gently pry off the battery.
7 other people completed this guide.
0 Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 73
All Time: 2,764
