Lenovo IdeaPad Flex 6-14IKB RAM Replacement
  1. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, Base Cover: step 1, image 1 of 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB RAM Replacement, RAM: step 3, image 1 of 1
    • Use the plastic opening tool to pry the protective cover off of the RAM.
  4. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 4, image 2 of 2
    • Unfasten the metal clips that secure the RAM.
  5. Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 5, image 1 of 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 5, image 2 of 3 Lenovo IdeaPad Flex 6-14IKB RAM Replacement: step 5, image 3 of 3
    • Remove the RAM from its slot on the motherboard.
One Comment
Thank you so much
Ayham Ka - Reply
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 51
All Time: 1,085
