Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement
  1. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, Base Cover: step 1, image 1 of 1
    • Remove the ten 6.5 mm screws that secure the base cover using a T5 Torx screwdriver.
  2. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to pry in the seam between the bottom cover and the rest of the laptop.
    • The goal is to unhook the plastic hooks that secure the bottom cover.
    • Work your way around the bottom cover of the laptop in a clockwise rotation until every clip is free.
    • You will feel and hear a clicking noise when the clips are undone.
  3. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement, SSD Card: step 3, image 1 of 1
    • Remove the single 3.5 mm screw that secures the SSD card using a Phillips #00 screwdriver.
  4. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 4, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to gently pry up the protective cover off of the SSD card.
  5. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 5, image 1 of 1
    • The SSD card will spring up to one side on its own.
  6. Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 6, image 1 of 2 Lenovo IdeaPad Flex 6-14IKB SSD Card Replacement: step 6, image 2 of 2
    • Remove the SSD from the motherboard.
    • When reinstalling the SSD, push the SSD card back into its slot. The SSD card will click into place when it is secure and then rest at a 30 degree angle from the laptop.
3 other people completed this guide.
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 27
All Time: 709
