Lenovo IdeaPad G50-45 DVD Drive Replacement
  1. Lenovo IdeaPad G50-45 DVD Drive Replacement, DVD Drive: step 1, image 1 of 1
    • First, remove the three screws located on the bottom panel of the laptop using a Philips #2 screwdriver.
    • To avoid losing the small screws, put them in a container.
  2. Lenovo IdeaPad G50-45 DVD Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: step 2, image 2 of 2
    • To remove the panel on the laptop, gently slide the panel away from the battery.
    • Make sure to slide the panel away before you lift to keep the panel from breaking.
    • Lift up the panel and place it to the side.
  3. Lenovo IdeaPad G50-45 DVD Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad G50-45 DVD Drive Replacement: step 3, image 2 of 2
    • Remove the indicated screw holding the DVD Drive.
    • To avoid losing the screw, place it in the same container used to hold the other three screws.
  4. Lenovo IdeaPad G50-45 DVD Drive Replacement: step 4, image 1 of 1
    • Push the now-free tab towards the DVD Drive using a flathead screwdriver.
    • Do not pry up the now-free tab.
  5. Lenovo IdeaPad G50-45 DVD Drive Replacement: step 5, image 1 of 1
    • Lastly, pull out the DVD Drive; it should come out easily.
6 other people completed this guide.
Saulo Gomes
601 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 21
All Time: 8,554
