Lenovo IdeaPad G50-45 Fan Replacement
  1. Lenovo IdeaPad G50-45 Fan Replacement, Fan: step 1, image 1 of 1
    • Safely flip the device upside down and use the Phillips head screwdriver to remove the 3 screws at the bottom of the device which are circled.
  2. Lenovo IdeaPad G50-45 Fan Replacement: step 2, image 1 of 1
    • Slide, do not lift, the bottom panel off once the 3 screws are off.
  3. Lenovo IdeaPad G50-45 Fan Replacement: step 3, image 1 of 1
    • Locate the fan in the upper right corner above the orange bar and appears as a silver semicircle.
  4. Lenovo IdeaPad G50-45 Fan Replacement: step 4, image 1 of 2 Lenovo IdeaPad G50-45 Fan Replacement: step 4, image 2 of 2
    • Remove the 3 screws attaching the fan to the device.
  5. Lenovo IdeaPad G50-45 Fan Replacement: step 5, image 1 of 1
    • Once the screws are removed slowly lift the fan out, there will be a thin wire connected to the device and fan still, Firmly grasp the white end of the wire where the wire splits into 2 and pull it out.
  6. Lenovo IdeaPad G50-45 Fan Replacement: step 6, image 1 of 1
    • The fan should be removed now and appear as so.
3 other people completed this guide.
Robert Muir
359 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,961
