Lenovo IdeaPad G50-45 Keyboard Replacement
  1. Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: step 1, image 1 of 2 Lenovo IdeaPad G50-45 Keyboard Replacement, Keyboard: step 1, image 2 of 2
    • Slide the two locking tabs away from each other to unlock the battery.
    • Remove the battery from the laptop once it is unlocked to prevent any electrical damage.
  2. Lenovo IdeaPad G50-45 Keyboard Replacement: step 2, image 1 of 1
    • Locate the three M2x6 screws on the bottom of the laptop base.
    • Use the #2 Phillips screwdriver to loosen and remove each screw.
  3. Lenovo IdeaPad G50-45 Keyboard Replacement: step 3, image 1 of 1
    • Slide the cover off and remove from the base.
  4. Lenovo IdeaPad G50-45 Keyboard Replacement: step 4, image 1 of 2 Lenovo IdeaPad G50-45 Keyboard Replacement: step 4, image 2 of 2
    • Locate the three M2x6 screws that secure the keyboard in place.
    • The screws are labeled with a keyboard emblem.
    • Loosen and unscrew the three M2x6 screws with the #2 Phillips screwdriver.
  5. Lenovo IdeaPad G50-45 Keyboard Replacement: step 5, image 1 of 1
    • Turn the laptop right side up once the screws that secure the keyboard to the base have been removed.
    • Pry around the keyboard to loosen it apart from the laptop with the spudger, beginning at the top left corner.
    • You will hear audible "clicks" as the keyboard is separated from the base.
  6. Lenovo IdeaPad G50-45 Keyboard Replacement: step 6, image 1 of 1
    • Lift the top of the keyboard up and forward once the top of the keyboard has been released.
    • Be VERY careful to remove the keyboard only a few inches to not damage the connecting ribbon cable.
  7. Lenovo IdeaPad G50-45 Keyboard Replacement: step 7, image 1 of 1
    • Lift the black locking tab with the spudger to release the connecting ribbon cable.
    • Disconnect the ribbon cable by pulling it straight out.
    • Be careful to not damage the ribbon cable with the spudger.
  8. Lenovo IdeaPad G50-45 Keyboard Replacement: step 8, image 1 of 1
    • Remove the keyboard after the ribbon cable is disconnected.
  9. Lenovo IdeaPad G50-45 Keyboard Replacement: step 9, image 1 of 1
    • When installing the replacement keyboard, first insert the bottom of the keyboard into the three slots of the base.
    • Complete the keyboard installation by pressing down on the top of the keyboard until you hear the clips snap back into place.
8 other people completed this guide.
Saulo Gomes
601 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Members
5 Guides authored
One Comment
I had an issue with the numbers at the top of alphabets. Some keys didn't work. I followed the instructions above to clean up the keyboard and hoped that would work. I could successfully remove and reassemble the keyboard but that didn't solve it.
I read it somewhere that this could be a hardware issue and the whole keyboard needs to changed. Is it really the case? Can't few keys be changed or fixed somehow?
Thank you.
Pritam Patil - Reply
Past 24 Hours: 3
Past 7 Days: 4
Past 30 Days: 24
All Time: 12,662
