Lenovo IdeaPad G50-45 Screen Replacement
  1. Lenovo IdeaPad G50-45 Screen Replacement, Screen: step 1, image 1 of 1
    • Remove the bezel by using the iFixit plastic opening tool to lift up an edge.
    • The bezel is the plastic lining along the edge of the screen.
  2. Lenovo IdeaPad G50-45 Screen Replacement: step 2, image 1 of 1
    • Finish removing the bezel by using your hand on the inside of the screen and popping it off.
    • If part of the bezel is stuck, start on the opposite side and work your way back to the area that is stuck.
    • The plastic on the hinges will pop off with the rest of the bezel.
  3. Lenovo IdeaPad G50-45 Screen Replacement: step 3, image 1 of 3 Lenovo IdeaPad G50-45 Screen Replacement: step 3, image 2 of 3 Lenovo IdeaPad G50-45 Screen Replacement: step 3, image 3 of 3
    • Remove the 4 screws located in each corner of the screen using the Phillips #2 screwdriver.
  4. Lenovo IdeaPad G50-45 Screen Replacement: step 4, image 1 of 1
    • Peel back the sticker that attaches the connector to the back of the screen.
    • Disconnect the cable that connects the screen to the computer.
    • There may be two cables.
  5. Lenovo IdeaPad G50-45 Screen Replacement: step 5, image 1 of 1
    • Test the new screen by turning it on before putting the bezel back on.
6 other people completed this guide.
Jessy McDermott
200 Reputation
1 Guide authored
UMass Dartmouth, Team 2-6, Shastany Fall 2015 Member of UMass Dartmouth, Team 2-6, Shastany Fall 2015
UMASSD-SHASTANY-F15S2G6
3 Members
5 Guides authored
2 Comments
The tutorial was pretty straightforward, and worked.
Remy G - Reply
My Laptop is got work the searen is blue it what trun on
Rebecca - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 27
All Time: 8,050
