Lenovo IdeaPad N586 Hard Drive Replacement
  1. Lenovo IdeaPad N586 Hard Drive Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaPad N586 Hard Drive Replacement, Battery: step 1, image 2 of 2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Hard Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad N586 Hard Drive Replacement: step 2, image 2 of 2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Hard Drive Replacement, Back Panel: step 3, image 1 of 1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Hard Drive Replacement: step 4, image 1 of 1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Now remove the last two screws highlighted
  6. Lenovo IdeaPad N586 Hard Drive Replacement: step 6, image 1 of 2 Lenovo IdeaPad N586 Hard Drive Replacement: step 6, image 2 of 2
    • Push hard drive away from the center of the chassis.
    • Lift the hard drive out of the chassis using the tab located on the drive.
Christopher
676 Reputation
6 Guides authored
Cal Poly, Team 8-7, Regan Spring 2014 Member of Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Members
10 Guides authored
One Comment
Please include that the back panel SLIDES out. I pried it out and broke off three of the retaining tabs. It easily slides out, and it would have been nice if that was in the directions. Most laptops panels are pried out.
stephenkingsley - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 2,174
