Lenovo IdeaPad N586 Memory Replacement
  1. Lenovo IdeaPad N586 Memory Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaPad N586 Memory Replacement, Battery: step 1, image 2 of 2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Memory Replacement: step 2, image 1 of 2 Lenovo IdeaPad N586 Memory Replacement: step 2, image 2 of 2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Memory Replacement, Back Panel: step 3, image 1 of 1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Memory Replacement: step 4, image 1 of 1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Memory Replacement, Memory: step 5, image 1 of 2 Lenovo IdeaPad N586 Memory Replacement, Memory: step 5, image 2 of 2
    • Now push the little clips out away from the memory to unlock the memory.
  6. Lenovo IdeaPad N586 Memory Replacement: step 6, image 1 of 1
    • After unlocking the memory from it's position, pull the memory out.
Christopher
676 Reputation
6 Guides authored
Cal Poly, Team 8-7, Regan Spring 2014 Member of Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 665
