Lenovo IdeaPad N586 Optical Drive Replacement
  1. Lenovo IdeaPad N586 Optical Drive Replacement, Battery: step 1, image 1 of 2 Lenovo IdeaPad N586 Optical Drive Replacement, Battery: step 1, image 2 of 2
    • To unlock the battery, flip the laptop over so that the bottom is facing upward. Then unlock the left clip by pushing the clip to the left.
  2. Lenovo IdeaPad N586 Optical Drive Replacement: step 2, image 1 of 2 Lenovo IdeaPad N586 Optical Drive Replacement: step 2, image 2 of 2
    • Now push the right clip to the right and hold it while using your other hand to pull the battery out.
  3. Lenovo IdeaPad N586 Optical Drive Replacement, Back Panel: step 3, image 1 of 1
    • Remove the two screws highlighted.
  4. Lenovo IdeaPad N586 Optical Drive Replacement: step 4, image 1 of 1
    • This is the back of the laptop with the cover removed.
  5. Lenovo IdeaPad N586 Optical Drive Replacement, Optical Drive: step 5, image 1 of 1
    • Locate and remove the single screw right of the optical drive
  6. Lenovo IdeaPad N586 Optical Drive Replacement: step 6, image 1 of 1
    • Optical Drive should slide out easily with one thumb's effort.
Christopher
676 Reputation
6 Guides authored
Cal Poly, Team 8-7, Regan Spring 2014 Member of Cal Poly, Team 8-7, Regan Spring 2014
CPSU-REGAN-S14S8G7
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 365
