Lenovo IdeaPad S10-2 Keyboard Replacement
  1. Lenovo IdeaPad S10-2 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Rotate the laptop so the back side is facing you.
    • From this side, you should be able to see both of the gaps where the two plastic materials meet.
  2. Lenovo IdeaPad S10-2 Keyboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad S10-2 Keyboard Replacement: step 2, image 2 of 2
    • Wedge the nylon or metal spudger inside the gap and pry open the two plastic parts.
  3. Lenovo IdeaPad S10-2 Keyboard Replacement: step 3, image 1 of 2 Lenovo IdeaPad S10-2 Keyboard Replacement: step 3, image 2 of 2
    • Open the laptop.
    • Place the nylon or metal spudger under the top half that is loose and pull up to pry it open.
  4. Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 1 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 2 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 4, image 3 of 3
    • Pull up on the loose component to remove.
    • As you lift the keyboard, you should be able to see a strip connected to the laptop.
  5. Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad S10-2 Keyboard Replacement: step 5, image 3 of 3
    • Remove the strip by pulling both sides of the blue strip out.
    • Lift and remove the keyboard from the laptop.
2 other people completed this guide.
Mary
132 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 3,261
