Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement
  1. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement, Wireless WiFi Card: step 1, image 1 of 1
    • The tools needed are the blunt edge of the spudger and a Phillips J0 head screwdriver.
    • Ensure your device is powered off before continuing.
  2. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 2, image 1 of 2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 2, image 2 of 2
    • Turn the laptop over to begin.
    • Remove the two 40 mm screws with a Phillips J0 head screwdriver.
  3. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 3, image 1 of 2 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 3, image 2 of 2
    • The WiFi card is found near the bottom of the panel.
  4. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 4, image 1 of 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 4, image 2 of 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Do not use the metal precision tweezers as shown.
    • Using the blunt end of the spudger, wedge the spudger beneath the connector and pull straight up to remove the white wire. Repeat to remove the black connector.
    • When reinstalling these U.FL connectors, hold the connector in place and gently push down. The connector should snap into place like a button.
  5. Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 5, image 1 of 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 5, image 2 of 3 Lenovo IdeaPad S10-2 Wireless WiFi Card Replacement: step 5, image 3 of 3
    • Remove the two 40 mm screws using a Phillips J0 head screwdriver.
    • Lift and remove the WiFi card.
Lucy Mendez
152 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,152
