Lenovo IdeaPad S340-15IWL CMOS Battery Replacement
  1. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: step 3, image 1 of 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: step 3, image 2 of 3 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement, CMOS Battery: step 3, image 3 of 3
    • Remove the circular CMOS battery on the far left side of the computer by lifting it with your finger or an opening tool.
    • This is only attached with adhesive, so it does not require extensive force.
  4. Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: step 4, image 1 of 2 Lenovo IdeaPad S340-15IWL CMOS Battery Replacement: step 4, image 2 of 2
    • Unplug the bundled red and black wires connecting the CMOS battery to the side of the device.
    • Remove the CMOS battery from the laptop.
2 other people completed this guide.
Kristen Gismondi
85,251 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,085 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 89
All Time: 1,900
