Lenovo IdeaPad S340-15IWL Fan Replacement
  1. Lenovo IdeaPad S340-15IWL Fan Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL Fan Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Fan Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Fan Replacement, Fan: step 3, image 1 of 1
    • Remove the two 3 mm screws connecting the fan to the casing using a Phillips #0 screwdriver.
  4. Lenovo IdeaPad S340-15IWL Fan Replacement: step 4, image 1 of 2 Lenovo IdeaPad S340-15IWL Fan Replacement: step 4, image 2 of 2
    • Using a spudger, gently disconnect the fan's cable from the motherboard.
  5. Lenovo IdeaPad S340-15IWL Fan Replacement: step 5, image 1 of 1
    • Carefully unwind the black cable that runs between the top of the battery and the bottom of the fan from the grooves along the side of the fan.
    • In order to do so, you will need to pull up the metallic tape that holds the cable in place using either your fingers or a plastic prying tool to lift up the edge.
    • If you attempt to remove the device’s fan without removing the battery, the black cable may be wedged underneath the top of the battery. In this scenario, it is recommended that you at least loosen the screws holding the battery in place to allow for the cable to be removed with less resistance.
  6. Lenovo IdeaPad S340-15IWL Fan Replacement: step 6, image 1 of 3 Lenovo IdeaPad S340-15IWL Fan Replacement: step 6, image 2 of 3 Lenovo IdeaPad S340-15IWL Fan Replacement: step 6, image 3 of 3
    • Carefully pick up the fan by the corners and detach the small connector wire by pulling parallel to the device.
    • Remove the fan from the laptop.
0 Comments
Past 24 Hours: 4
Past 7 Days: 10
Past 30 Days: 41
All Time: 894
