Lenovo IdeaPad S340-15IWL Hard Drive Replacement
  1. Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Hard Drive Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: step 3, image 1 of 3 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: step 3, image 2 of 3 Lenovo IdeaPad S340-15IWL Hard Drive Replacement, Hard Drive: step 3, image 3 of 3
    • Remove the four 3 mm screws holding the hard drive expansion slot in place using a Phillips #0 screwdriver.
Kristen Gismondi
85,251 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,085 Guides authored
One Comment
I managed to take the case apart once, but when I tried to put back the Torx screws back in, I noticed one wouldn't go more than halfway -- it then turned freely. I'd ordered an SSD thinking that it would be a simple matter to install it, but I found that half the Torx screws wouldn't come out, even using a tiny screwdriver to try to prise them out while turning the Torx wrench. They're seated in brass sleeves -- no way I stripped those out; the sleeves must be glued into the plastic of the case and the glue given out. There now seems to be no way to take the case apart without destroying it completely.
Robert - Reply
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 68
All Time: 2,368
