Lenovo IdeaPad S340-15IWL Video Cable Replacement
  1. Lenovo IdeaPad S340-15IWL Video Cable Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL Video Cable Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Video Cable Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Video Cable Replacement, Battery: step 3, image 1 of 2 Lenovo IdeaPad S340-15IWL Video Cable Replacement, Battery: step 3, image 2 of 2
    • Disconnect the battery cable by gently pulling it straight out of the connector.
    • Be sure to pull parallel to the device to avoid bending the motherboard connector.
    • The battery connector does not lock and only requires light pressure to insert and remove.
    • Remove the battery from the laptop.
  4. Lenovo IdeaPad S340-15IWL Video Cable Replacement, Video Cable: step 4, image 1 of 3 Lenovo IdeaPad S340-15IWL Video Cable Replacement, Video Cable: step 4, image 2 of 3 Lenovo IdeaPad S340-15IWL Video Cable Replacement, Video Cable: step 4, image 3 of 3
    • Using an opening tool, carefully flip up the retaining flaps holding the silver video cable in place.
    • Slide the ribbon cable out of each connector.
Kristen Gismondi
84,844 Reputation
215 Guides authored
iFixit Member of iFixit
Staff
141 Members
17,895 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 15
All Time: 434
