Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement
Kristen Gismondi
Kristen Gismondi and one other contributor
Last updated on March 26, 2024
No estimate
Moderate
Better Introduction
Missing Details
Parts
Tools
Show more…
  1. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: step 1, image 1 of 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop and place it face-down on a non-scratching surface.
    • Using a Torx T5 screwdriver head, remove all ten 6 mm screws holding the back panel in place.
  2. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: step 2, image 1 of 1
    • Slide a plastic opening tool underneath the back case near the screen hinges.
    • Gently pry up on either side of the case.
    • You may hear popping sounds as you pry up the back case. This is normal. If the case does not open, try prying at a different angle/position.
  3. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 1 of 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement, Wi-Fi Card: step 3, image 2 of 2
    • Pull up the black foam adhesive that covers the screw and connectors holding the Wi-Fi card in place.
  4. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: step 4, image 1 of 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: step 4, image 2 of 2
    • Using an opening tool, lift up on the black and white coaxial cables on the Wi-Fi card and gently pull upward to unplug them.
    • When reconnecting the cables, be sure to match the colors to the arrows on the Wi-Fi card.
  5. Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: step 5, image 1 of 2 Lenovo IdeaPad S340-15IWL Wi-Fi Card Replacement: step 5, image 2 of 2
    • Remove the single 3 mm screw holding the Wi-Fi card in place using a Phillips #0 screwdriver.
    • Gently lift the Wi-Fi card out of the computer.
Kristen Gismondi
92,285 Reputation
241 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,540 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 66
All Time: 1,691
