Lenovo IdeaPad U410 Battery Replacement
  1. Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo IdeaPad U410 Battery Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Battery Replacement: step 2, image 1 of 3 Lenovo IdeaPad U410 Battery Replacement: step 2, image 2 of 3 Lenovo IdeaPad U410 Battery Replacement: step 2, image 3 of 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Battery Replacement, Battery: step 3, image 1 of 1
    • Make sure your computer is turned off.
    • Lift the back panel away from you.
    • Locate the battery in the bottom right corner.
  4. Lenovo IdeaPad U410 Battery Replacement: step 4, image 1 of 1
    • Remove the three 3mm screws located on the perimeter of the battery using the Phillips #1 screwdriver.
  5. Lenovo IdeaPad U410 Battery Replacement: step 5, image 1 of 3 Lenovo IdeaPad U410 Battery Replacement: step 5, image 2 of 3 Lenovo IdeaPad U410 Battery Replacement: step 5, image 3 of 3
    • Locate the small rectangle shaped connector to the left of your battery.
    • Use your fingers to gently detach the white connector.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 848
