Lenovo IdeaPad U410 Hard Drive Replacement
  1. Lenovo IdeaPad U410 Hard Drive Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo IdeaPad U410 Hard Drive Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Hard Drive Replacement: step 2, image 1 of 3 Lenovo IdeaPad U410 Hard Drive Replacement: step 2, image 2 of 3 Lenovo IdeaPad U410 Hard Drive Replacement: step 2, image 3 of 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Locate the hard drive in the bottom left corner.
  4. Lenovo IdeaPad U410 Hard Drive Replacement: step 4, image 1 of 2 Lenovo IdeaPad U410 Hard Drive Replacement: step 4, image 2 of 2
    • Use the Phillips #1 screwdriver to remove the three 3mm screws located on the rim of the hard drive.
  5. Lenovo IdeaPad U410 Hard Drive Replacement: step 5, image 1 of 3 Lenovo IdeaPad U410 Hard Drive Replacement: step 5, image 2 of 3 Lenovo IdeaPad U410 Hard Drive Replacement: step 5, image 3 of 3
    • Use your fingers to detach the black connector from the hard drive.
  6. Lenovo IdeaPad U410 Hard Drive Replacement: step 6, image 1 of 2 Lenovo IdeaPad U410 Hard Drive Replacement: step 6, image 2 of 2
    • Unscrew the four screws on either side of the hard drive with the Phillips #1 screwdriver.
  7. Lenovo IdeaPad U410 Hard Drive Replacement: step 7, image 1 of 1
    • Use your fingers and gently lift the hard drive from the case it was screwed into.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 1,133
