Lenovo IdeaPad U410 Solid State Drive Replacement
  1. Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: step 1, image 1 of 2 Lenovo IdeaPad U410 Solid State Drive  Replacement, Bottom Cover: step 1, image 2 of 2
    • Using the metal spudger, remove all the rubber squares on the bottom of the laptop.
  2. Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 1 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 2 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement: step 2, image 3 of 3
    • Remove the three 6 mm Phillips #1 screws holding the panel on the laptop.
    • Pry the panel from the laptop using your hands or the metal spudger if necessary.
  3. Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 1 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 2 of 3 Lenovo IdeaPad U410 Solid State Drive  Replacement, Solid State Drive: step 3, image 3 of 3
    • Make sure your laptop is powered off.
    • Use a Phillips #1 screwdriver to remove the 3 mm screw holding the SSD in place.
  4. Lenovo IdeaPad U410 Solid State Drive  Replacement: step 4, image 1 of 1
    • Grab the SSD and pull it out from the mSATA slot.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 706
