Lenovo IdeaPad U430 Touch Charging Port Replacement
  1. Lenovo IdeaPad U430 Touch Charging Port Replacement, Bottom Cover: step 1, image 1 of 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Charging Port Replacement: step 3, image 1 of 2 Lenovo IdeaPad U430 Touch Charging Port Replacement: step 3, image 2 of 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Charging Port Replacement, Charging Port: step 4, image 1 of 2 Lenovo IdeaPad U430 Touch Charging Port Replacement, Charging Port: step 4, image 2 of 2
    • Disconnect charging port from motherboard.
    • To do this, press the spudger on the center dimple and push the connector out.
  4. Lenovo IdeaPad U430 Touch Charging Port Replacement: step 5, image 1 of 2 Lenovo IdeaPad U430 Touch Charging Port Replacement: step 5, image 2 of 2
    • Pry the charging port out of the socket with a metal spudger.
    • It may be necessary to pry from each side.
  5. Lenovo IdeaPad U430 Touch Charging Port Replacement: step 6, image 1 of 1
    • Remove charging port from laptop.
Patrick Ripkey
627 Reputation
5 Guides authored
USF Tampa, Team S2-G6, Nance Spring 2017 Member of USF Tampa, Team S2-G6, Nance Spring 2017
USFT-NANCE-S17S2G6
3 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,258
