Lenovo IdeaPad U430 Touch Hard Drive Replacement
  1. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Bottom Cover: step 1, image 1 of 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Hard Drive Replacement: step 3, image 1 of 2 Lenovo IdeaPad U430 Touch Hard Drive Replacement: step 3, image 2 of 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Unplug the hard drive from the 22-pin cable (LZ9 HDD cable).
    • At the time of guide creation, the device did not come equipped with the hard drive.
  4. Lenovo IdeaPad U430 Touch Hard Drive Replacement: step 5, image 1 of 1
    • Using the plastic opening tool, lift the hard drive from its compartment.
One Comment
1. Of the first 10 screws, you did not mention that 2 of them are longer.
2. You can't lift the hard drive out without removing 4 screws (one at each corner of the drive). The plastic tool is not needed for this.
Todd McQueen - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,580
