Lenovo IdeaPad U430 Touch Wifi Card Replacement
  1. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Bottom Cover: step 1, image 1 of 1
    • Power off your computer before you begin.
    • Find and remove the 10 Phillips style body screws on the bottom of the laptop case.
    • Remove 2 screws, 1 located on the left hinge cover and one located on the right hinge cover.
  2. Lenovo IdeaPad U430 Touch Wifi Card Replacement: step 3, image 1 of 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: step 3, image 2 of 2
    • Starting from the front, use a plastic opening tool to separate the bottom of the case from the body of the laptop.
  3. Lenovo IdeaPad U430 Touch Wifi Card Replacement, Wifi Card: step 4, image 1 of 1
    • Remove the two 2.8mm screws using the Phillips #0 screwdriver.
  4. Lenovo IdeaPad U430 Touch Wifi Card Replacement: step 5, image 1 of 2 Lenovo IdeaPad U430 Touch Wifi Card Replacement: step 5, image 2 of 2
    • Remove the two snap cables connecting the wifi card to the rest of the computer.
  5. Lenovo IdeaPad U430 Touch Wifi Card Replacement: step 6, image 1 of 1
    • Slide the Wifi card away from the Wifi card connector.
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 606
