Lenovo IdeaPad U450 Fan Replacement
  1. Lenovo IdeaPad U450 Fan Replacement, Battery: step 1, image 1 of 1
    • Turn off and unplug your laptop to prevent the risk of electrocution.
    • Turn your laptop over so that the bottom is face up.
  2. Lenovo IdeaPad U450 Fan Replacement: step 2, image 1 of 1
    • On the top left of the laptop there is a switch. Make sure it's pushed in the unlocked position.
  3. Lenovo IdeaPad U450 Fan Replacement: step 3, image 1 of 1
    • Locate the switch collinear with the last one and move the switch to an unlocked position.
  4. Lenovo IdeaPad U450 Fan Replacement: step 4, image 1 of 1
    • Remove the unlocked battery.
  5. Lenovo IdeaPad U450 Fan Replacement, Top Panel: step 5, image 1 of 1
    • Turn the laptop over so that the bottom is facing up.
  6. Lenovo IdeaPad U450 Fan Replacement: step 6, image 1 of 1
    • Remove all 7mm phillips head screws using the Phillips #00 screwdriver.
  7. Lenovo IdeaPad U450 Fan Replacement: step 7, image 1 of 1
    • Turn the laptop over again and open the laptop.
  8. Lenovo IdeaPad U450 Fan Replacement: step 8, image 1 of 1
    • Gently lift up the top panel utilizing the hole where the battery would be.
    • Keyboard ribbon cable is still connected. Flip the ZIF connector up and remove the ribbon cable.
  9. Lenovo IdeaPad U450 Fan Replacement: step 9, image 1 of 1
    • Disconnect any wires that are connected to the top panel from the bottom of the laptop.
  10. Lenovo IdeaPad U450 Fan Replacement, Fan: step 10, image 1 of 1
    • Unplug the bundled fan connector from the motherboard.
  11. Lenovo IdeaPad U450 Fan Replacement: step 11, image 1 of 1
    • Unscrew all screws that hold the fan down using the Phillips #00 screwdriver.
  12. Lenovo IdeaPad U450 Fan Replacement: step 12, image 1 of 1
    • Remove the fan from the slot.
Anna Church
146 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 402
