Lenovo IdeaPad Y410p Keyboard Replacement
  1. Lenovo IdeaPad Y410p Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Keyboard Replacement: step 2, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement: step 2, image 2 of 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Keyboard Replacement: step 3, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement: step 3, image 2 of 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: step 4, image 1 of 2 Lenovo IdeaPad Y410p Keyboard Replacement, Keyboard: step 4, image 2 of 2
    • Power off your laptop.
    • Use a metal spudger to loosen the frame of the keyboard by running it under the edges of the keyboard as shown.
    • After loosening the keyboard frame, you should be able to gently lift up the keyboard.
  5. Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 1 of 3 Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 2 of 3 Lenovo IdeaPad Y410p Keyboard Replacement: step 5, image 3 of 3
    • Be careful when lifting the keyboard so that you do not damage the ribbon cable connector.
    • Detach the ribbon cables from the latches shown.
2 other people completed this guide.
2 Comments
Terrible guide - completely fails to point out the two screws that hold the keyboard down underneath the bottom casing. Bent my keyboard thanks to this.
Dragon - Reply
Awful guide. Wish I'd seen the other comment before I also ruined my keyboard. Thought it popped out, but there's 2 screws under the bottom case that hold it (remove!) … bent the keyboard frame and ripped the screw tabs off. Was just trying to clean it. Now it needs total replacement.
How is this article reportable?
Nateb - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 984
