Lenovo IdeaPad Y410p Ram Replacement
  1. Lenovo IdeaPad Y410p Ram Replacement, Battery: step 1, image 1 of 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers are facing up.
  2. Lenovo IdeaPad Y410p Ram Replacement: step 2, image 1 of 2 Lenovo IdeaPad Y410p Ram Replacement: step 2, image 2 of 2
    • Slide the left battery lock to the unlock position and release.
    • Slide the right battery lock to the unlock positon and hold it in place.
  3. Lenovo IdeaPad Y410p Ram Replacement: step 3, image 1 of 2 Lenovo IdeaPad Y410p Ram Replacement: step 3, image 2 of 2
    • While holding the right battery lock in the unlock position, slide the battery carefully out of the laptop and set it aside.
  4. Lenovo IdeaPad Y410p Ram Replacement, Ram: step 4, image 1 of 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: step 4, image 2 of 3 Lenovo IdeaPad Y410p Ram Replacement, Ram: step 4, image 3 of 3
    • Using the Phillips #0 screwdriver remove the eight 8mm screws that fasten the bottom cover.
    • Lift the bottom cover off using a metal spudger and set it aside.
  5. Lenovo IdeaPad Y410p Ram Replacement: step 5, image 1 of 2 Lenovo IdeaPad Y410p Ram Replacement: step 5, image 2 of 2
    • Simultaneously pull apart both clips that are holding the RAM module down.
    • When the RAM module is released carefully pull it out.
  6. Lenovo IdeaPad Y410p Ram Replacement: step 6, image 1 of 2 Lenovo IdeaPad Y410p Ram Replacement: step 6, image 2 of 2
    • There is a second ram module under the first one.
    • Repeat Step 5 with lower Ram module.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 19
All Time: 869
