You're viewing a previously published version of this guide.  View latest version
Older Newer
Lenovo IdeaPad Y500 Battery Replacement
Tatum Hennige
Tatum Hennige and 2 other contributors
Last updated on January 5, 2021
1 minute
Very easy
Introduction
Go to step 1
Use this guide to replace the battery in your device. Removing the battery will help you replace other parts of your device.
  1. Lenovo IdeaPad Y500 Battery Replacement, Battery: step 1, image 1 of 3 Lenovo IdeaPad Y500 Battery Replacement, Battery: step 1, image 2 of 3 Lenovo IdeaPad Y500 Battery Replacement, Battery: step 1, image 3 of 3
    • Slide the lock on the right side until you hear a click. Once you hear a click , you should see the color red.
  2. Lenovo IdeaPad Y500 Battery Replacement: step 2, image 1 of 1
    • Unlike the first lock, this lock is spring loaded and must be held in place when used.
    • Slide the lock to the left (in the direction of the arrow below the lock) and hold in place.
  3. Lenovo IdeaPad Y500 Battery Replacement: step 3, image 1 of 1
    • Gently pull battery away from the computer while holding open the lock.
Tatum Hennige
687 Reputation
4 Guides authored
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 10
All Time: 600
